I suspected my relatively new ball joints were junk, and today put a jack under my lower control arm to check, but the ball joints are free of any slop.
However the wheel bearings, replaced ~8 months ago, had some play. I pop off the dust cap, cotter pin and castle nut and main nut and washer, remove the outer bearing, and the thing is pristine.
I clean it, repack it with grease, re install it and finger tighten the nut, and the nut runs out of threads on the spindle. I try a wrench, but no more threads. The washer is bottoming out on the spindle, the nut cannot push it any deeper
There is about 1/16 slop when pulling and pushing on the top of the tire, and that tire was showing uneven wear.
Now I can understand if this happened when I first installed these bearings, or if the bearings were chewed up, but it seems to me as if the recesses in the rotors for the races were just machined too deeply, or there is something I am missing.
Anybody run into this?
3/4 ton dodge Van of legal drinking age
