As Ray has pointed out....and what I have read supports.
There are 3 main types of Ethylene Glycol coolants.
DEXCOOL is a Organic Acid Technology (OAT) type of coolant.
A LOT of coolants out there state "No Silicates, no Phosphates", which make them also a OAT type of coolant.
Some people lump all OAT coolants that do not state "Dexcool" on the label as "Dexcool Clones".
These are LONG LIFE.
G-05, G-12 and other coolants that use Silicates or Phosphates are called Hybrid Organic Acid Technology (HOAT) type coolants.
These are still LONG LIFE, but have a small amount of the traditional Silicate or Phosphate to provide "instant protection" until the other additives can build up the protective layer.
Then there is the "Traditional Green", which, as I have read, contains less silicates than it did years ago, but is still NOT LONG LIFE, and should be changed on the shorter interval.
In all 3 types, Ethylene Glycol is the major component, the difference between the 3 major types is the additive package.
You should still use all 3 in the recommended 50/50 mix.
Within each type, it stands to reason, as mentioned here, there will be differences in this additive package.
