So, I was trying to explain to a friend the reasons why he should change his brake fluid at least every 15 years, and realized that I myself have a hole in my understanding of hydraulics.
A reason I was given was that as the fluid absorbs water, the boiling point is lowered. When the fluid boils, it becomes a gas (of course), and gasses are compressible. Compressible gasses = spongy pedal.
From wikipedia, mirroring my memory almost word for word:
"Fade can also be caused by the brake fluid boiling, with attendant release of compressible gases. In this type of fade, the brake pedal feels "spongy". This condition is worsened when there are contaminants in the fluid, such as water, which most types of brake fluids are prone to absorbing to varying degrees. For this reason brake fluid replacement is standard maintenance."
So here's where I'm at a loss.
You have a fixed volume. Unless your master cylinder has a bad seal, or your caliper(s), it's an enclosed system. If it gets hotter, where is there ROOM for a gas pocket to form?
We were taught in grade school that the very definition of a liquid/fluid, is that it is non compressible.
For a gas to make space for itself in a closed system full of fluid that's been heated, either there's a leak to the outside volume, or, fluids ARE compressible but just to a lesser extent than gasses? The latter seems more likely.
But even if you filled a pressure cooker with brake fluid and no air gap and turned on the heat, and the fluid gets denser while air bubbles form in the same volume... the air bubbles are still under the exact same pressure, and should still transmit the same forces, right?
So the pedal cannot fade to the floor. If the air bubbles are from boiled fluid in the same volume, they should be under the same pressure and transmit your braking force just as surely as the fluid would have, no?
I may be missing something fundamental in my education about fluid dynamics (admittedly not that much education), and I'd like to understand more thoroughly.
