Dual feed th 400
Going to dual feed a th 400 Im building.
Leave center seal in direct drum, no second seal in center support and block this hole in the transmission? I thought a small 3/8” freeze plug should fit? So bought some pioneer PIOEPC107 plugs. With the transmission upside down they are to big for the lower part of the hole and to small for the upper. Should I use something else to block it with or is the 3/8” size wrong?
