- Joined
- Jun 2, 2003
- Messages
- 23,587
The rubber boots on the guide pins keep moisture out. Since the guide pins are lubed and stuck tightly in the caliper "holes," suction will naturally occur, which makes the sliding action springy.quote:
Hmmm... may be the rubber caps on the sliders' bolt heads were probably for better air sealing ?.. I was curious why there were rubber boots, and if for rust, why no boot for the bleeder screw.
The bleeder nipples have rubber caps.
