quote:
Originally posted by Rodbuckler:
quote:
Originally posted by Craig in Canada:
As I mentioned, HP is irrelevant and can be pretty much ignored.
Figuring out how fast a car will be from x to y mph is a mathematical function of integrating (summing) the area under the torque curve and using a transmission map to determine shift points to maximize this area.
Sorry to disagree Craig, but this is about as wrong as it gets. To accelerate the car the hardest, you run through the gears with the engine in the POWERBAND. If you want your car to accelerate twice as hard as stock, you double the engine POWER or cut the car weight in half.
It's the area under the POWER curve that matters. The engine torque output is largely irrevelant. The transmission has gears so that you can keep the engine in the POWERBAND if you are serious about accelerating the car.
Also, horsepower and torque are never equal. The 5252 is just a units conversion factor, and has no physical interpretation whatsoever. Ignore it. We plot HP and torque vs. RPM on the same sheet of paper for convenience only.
I'm afraid that you're incorrect.
Well, let's break this down. TORQUE is a force, and POWER is a measure of work done (in the physics sense) which is defined as "force through a distance".
Acceleration of a simple body follows Newton's law F=ma, or to solve for acceleration a=F/m. All units are metric, so force in Newtons, mass in kg, and acceleration in m/s^2.
How is a car accelerated forward? It can only be accelerated along the ground by a force parallel to the ground. Where does this come from? The wheels. Wheels translate a rotational force from the drivetrain into a linear force at the ground. This linear force alone is responsible for accelerating the vehicle forward and is expressed in weight-like quantities (Newtons, in the most basic case without doing conversions). At this point it's more like dealing with thrust, which sometimes is measured in pounds. If you want to accelerate a 1000kg car at 1g (ie. Porsche Turbo), 1g=9.8m/s^2 so
F = 1000kg * 9.8m/s^2 = 9800Newtons
A Newton is defined as the force which, when applied to one kilogram mass, causes an acceleration of 1 meter/sec2. So a kilogram weight under gravity creates a force of 9.8N. So we simplify back to 1000kg (equivalent) or 2200lbs of linear force are required for this acceleration example. I know mass and weight aren't the same thing, but that's not the topic here.
As I said, this linear force is derived from the drivetrain which provides a rotational force. Rotational forces are defined as a force acting at a distance from the center of rotation. This leads to the units ft-lb (one pound of force applied to a one foot radius from center along a tangent of the circle) to measure twisting force. In metric, Newton-meters is used (you've all seen this on your metric torque wrenches).
So, if you need 9800 Newtons (2200lbs) to accelerate your vehicle at 1g, and you have 24" tires (outer diameter, not rim size) you will require a torque at the wheel of 2200 ft-lbs. A 24" diameter wheel has a radius of 12".
The transmission and final gearing provide torque multiplication factors from the engine's base torque output. By gearing down you increase torque, hence 2200 ft-lbs at the wheels can be possible in, say, first gear on some very nice cars.
So, through this crappy example I've illustrated that FORCE is required to cause the acceleration of a rolling body. Horsepower, being a measurement of POWER, is force through a distance. In this case, the "distance" is rotational so RPM is used. Actually, to get specific, RPM is already a complex unit (revolutions per minute) that also involve time, so it gets more complex. The '5252' from the equation is mostly a scalar to translate from metric into imperial units, radians into revolutions etc...
How do you propose to take F=ma and turn it into F*revs/minute=ma? The units are wrong for the equations, and mathematics won't allow you to simply add distance (RPM) to one side of the equation of carry on as if nothing happened. The very fact that horsepower is DERIVED from torque should tell you that torque is the actual motivating force involved.
Horsepower ratings are only indicating that your engine can continue to provide a certain torque while spinning at a given speed. Generating 100 ft-lbs of twist at 10,000RPM requires a lot more energy than at 10RPM, hence a lot more "work" is done, hence it is still a measure of engine output. It is not, however, the basic source of acceleration.
The road acceleration of the vehicle depends SOLELY on the linear force applied at the road, which is the twisting force from the drivetrain, minus wind resistance etc... The mass being accelerated doesn't care how fast your engine is spinning, or how fast it is already going, as long as the twist is there.
So - find the *torque* peak of your power plant and use the transmission to convert between wheel speed and engine speed so you can keep the engine near peak "regardless" of your road speed.
To clarify my 'integrate under the torque curve', it is most correct to integrate under the output torque curve of the transmission, accounting for the multiplication factor of each gear to derive optimum shift points. I've never actually bothered, I drive by feel and sound.
Craig.
