Sure,
@Shel_B no problem. Short answers: You increase fuel economy a little, standard increase rolling resistance. It has been said increase payload (like if I show up with 60 gallons antifreeze in my car, as an example. And even if it wasn't loaded down with weight) and some feel you help save the life of the tire and help the sidewall see less heat, I've read this places. Maybe because more squared between tread and sidewall. That last one is probably nonsense, but I have always noticed a slightly quicker feel when the pressure is up. They say you should lower it in winter months if you see snow, that would have to be an extreme case.
https://www.consumerreports.org/cro...ires-cool-amid-damaging-summer-heat/index.htm
I do realize the statements
fuel economy and
increased load capacity (of the tires) may be contradictory, but. Couple that with cruise control, and while I frequently but not always set cruise at 75MPH in my years of developed driving habit.. you're not winning any races but you drive with the road and make time, situation by situation .. you're probably doing your tires a favor, if not your wallet, over many miles.
You would be more likely to see wear on the inside of the tire first but it will be wearing anyway.
Hypermilers inflate it way, way, way higher than that and gets to the points of unsafe. I used to inflate higher than 40 but now, with age and wisdom, I think 40 is a fair inflation for a tire. Then it is also said the placard is for the tire that came with the car. Plus, the hot summer months, highway at speed for hours.. higher than 40 is probably really pushing it.
Overall, I concur with the first response in this linked article here, fellow named David Sandbrook, as to why:
https://www.quora.com/Will-it-ruin-...n-the-recommended-psi-is-35?top_ans=126028298
