Just a quick comparison between a stick sport coupe I am learning to drive with (88 Integra in perfect condition) and a 92 Corolla automatic daily driver I have. While it is fun to throw the stick around and "select" my own gear, I think the joy factor is highly over-rated and the technology is truly obsolete.
1) Once highway speed is achieved, either car would be in the highest gear and that would take up at least 80% of the driving most people do.
2) On twisty hilly roads where a manual supposes to shine, I can see the advantage as far as lower fuel consumption and 'perceived' sporty feeling. However, I think people would do better if they just keep both hand on the steering wheel and concentrate on making that turn perfectly using their gas pedal.
3) Stop-n-go traffic is a no brainer, especially if lane merging is involved.
4) Same for city driving.
I am learning to drive a stick because chances are a used truck or off-road vehicle I am buying in the future would be in stick. It is one way to eliminate having to worry about whether a transmission will hold up. A clutch job is roughly 600-800 dollars, which is way cheaper than an auto rebuild. However, I think a good driver can have an auto to last as long as the manual. For safety factor, the auto transmission far exceed the manual. An auto can also be shifted if there is ever a true need. I tried to take my transmission off Over-Drive on mountain path before to save on the brake and utilize the higher rpm from a lower gear. However, I end-up using more gas that way.
So, beside the cave man sense of need to have "driver engagement" is there a reason to have a stick? For the record, my definition of driver engagement is knowing your vehicle well and be able to drive it the most efficiently, not just in fuel consumption for longevity of parts such as brake, engine, transmission, etc.
