So I decided on a whim to install my police Aluminum driveshaft in place of the stock steel unit. This piece is shorter than the steel one and in the PIs is paired with a extended output shaft and extended housing. The yoke is longer on the PI shaft as well, 6.25" in length instead of 5". With a small detail; The stock yoke is splined to the end, and the extended yoke only has splines on the bottom 4".
I made a diagram of how it fits in the stock short housing and output shaft.
My thought is that it will probably have reduced critical speed, due to the shorter housing providing less support. However, Critical limit with my final drive is over 160mph, so even if I clip 25% off thats still faster than I would want to go.
Anyway, so I was messing with it today, and grabbed the driveshaft at the front u-joint. I found the yoke moved around about 1/16-1/8" all around inside the trans. Is that excessive? I didnt play with my OE shaft before I pulled it so Im not sure of what normal is. It does not vibrate or anything, even up to 80mph. Ive played with putting it in different gears, so I change engine and exhaust noise to kind of listen for what does not change, but Ive got nothing.
Thoughts? My thought was to pull the yoke off the stock shaft and put it on the Alum shaft. Its shorter, but has full splines so actual contact is higher; around 3.25". Then, putting on a .75" driveshaft spacer will bump it to almost identical with stock.
