wemay
Site Donor 2023
https://www.turnology.com/tech-stor...fic-oil-could-save-your-ecoboost-engine/
"In the United Kingdom there is a racing series called the Mini Challenge, where the race engines run direct injection. After a rash of engine failures at races, the series organizers sought out a solution.
After identifying the increased chance of low-speed pre-ignition in direct-injection applications, Driven Racing Oils developed is line of DI oils. They are available in 0-W20, 5-W30, 0-W40, and 10-W60. (Photo Credit: Driven Racing Oil)
"Once the series organizers and engine builder became aware that failures were due to LSPI, the series fuel supplier, Sunoco recommended contacting Driven Racing Oil," Lake Speed Jr., Lubrication Specialist at Driven Racing Oil, said. "That call resulted in a change to Driven's XP9 Racing Oil that contained only 250 ppm of Calcium detergent compared to the previous oil with more than 2,500 ppm of Calcium. Just changing the Calcium level eliminated the LSPI related engine failures."
