Will soon be time for another change of all the driveline fluids. Truck is an '08 Ram 4.7L 4x4 with ~120k miles, Getrag 238 6spd transmission, and open f&r differentials.
Factory specs:
G238 trans - ATF+4
transfer case - ATF+4
front diff - 80w90
rear 9.25 diff - 75w140
What I have been running, at 60k intervals under severe service:
G238 trans - Redline C+ ATF (1st change), Redline D4 ATF (2nd change)
transfer case - Redline C+ ATF (1st change), Redline D4 ATF (2nd change)
front diff - Redline 75w90
rear diff - Redline 75w140
Figured that a manual trans & transfer case wouldn't require the extra friction modifier in ATF+4, hence the change to D4 ATF 2nd time around.
I would like to extend drain intervals to the 80k-100k mile range, and this is under all types of severe service. Think the Redline would be able to go the distance, or am I better off with a different oil?
Factory specs:
G238 trans - ATF+4
front diff - 80w90
