My saturn throttle bodies gum up with PCV related junk every 10k miles or less. Feel it in the pedal. Bet the little butterfly actuating motor will give up and start throwing codes... or, of course, overheat and die an expensive death. One would need catch cans etc for the fumes to collect in.
Had a newish corrolla rental that would upshift 1-2 at around 3k RPM when it was cold, even at WOT. Am sure that was an anti-abuse measure.
Have heard of a car that has a sluggish "city" mode but picks up responsiveness when it gets going 40 mph. Can only imagine the idiots flying down the highway, wasting gas, b/c it's so fun to drive all of a sudden.
Dual potentiometers mean redundancy, sure, but I assume the computer would select the slower of two readings. The lawyers must have planned carefully to prevent audi 5000 style lawsuits. Personally think a sealed optical pickup would work better.
Am not as bothered by TBW's presence on automatic transmission cars as control was already ceded by getting the slushbox. As said above controlling torque during shifts and other conditions saves wear on those gearboxes. Wife has an aunt who's just "hard on transmissions", I have never ridden with her but she could probably use some anti-abuse programming.
Bummer is if 10% of the cars come with a stick the PCM programming will still be auto-style and the throttle parts will be the same. My saturns, for smog reasons, hold the idle speed bypass (which has existed since computerized feedback carb days) open during shifts, so the RPMs float well above idle or even above the speed needed for the next gear.
Kind of off topic but in response to your "heat related death" comment, I plugged the coolant off to the throttlebody and it now stays cool to the touch. It was primarily for performance since I live in a hot climate but in the back of my mind I was wondering if it could potentially help the life of the DBW system.
