And they don't seem to sell push in single caps AFAIK.
This.Or drive a "nylon" (white plastic) machine screw into the hole taking advantage of plastics' give.
The battery likely is on its last legs anyway with that much water needed. Try using a screw to fill the holes in the caps. Tape won't work.Simply the battery was low on water as it has been a few years of use. And bat took 1/4 gallon of DI to fill up
Now I have holes to seal. I drilled a hole and used a screw to pull out the caps.
It is a sealed battery, but all batteries, if you are aware are not sealed. water has to be added at factory.
It is a Duracell, and the caps all fit flush with top.
I think will try electric tape.
A good idea and can then have a pull handle.The nylon screw suggestion is probably the way to go .
Sure, but I think I bought this as it was cheap at Walmart.Next Time buy a Servicable Battery
316 is also Marine grade and common as muck.It’s not, a lot of stainless hardware is 18-8. 316 is “medical” aka highly corrosion resistant.
Why chop them off?I cant believe you drilled holes... Anyway how about chopping off some plastic golf tees and shoving them in the holes?
