So I had 4 new Potenza RE960's put on about 4k ago.
I then had them aligned as there was a severe pull.
Sure enough, the alignment showed that my right front toe was over the max spec.
So driving the car along, it definitely feels balanced and aligned.
However, the car drifts right on FLAT roads.
So I take it back to the alignment shop and they say it is still aligned. I then have the tires rotated and balanced (back to front directly as they are unidirectional) and the problem is exactly the same.
So clearly the tires are ok since the 2 backs are behaving exactly like the 2 fronts.
I look back over my secondary angles and the SAI shows the following;
Left below min spec by 1 degree. Right above max spec by 2 degrees. At the alignment nothing was changed.
I read that on some cars SAI cannot be changed. So my question is, is this the cause of my drifting? And can anything be done?
Thanks!
Thanks!
