I am planning on doing a drain and fill of the transmission and radiator on the Accord tomorrow. I have to drive to the dealer to get the parts so the car will be warmed up. I don't have any problem draining the trans while hot, but I know the radiator is under pressure. Is there a safe way to drain it when its hot/warm or do you have to wait until its cold. Is it safe to open the drain plug on the radiator to let some pressure out and then open the cap on top? If not, how long should I wait before opening it up. I mean the techs at the dealership have to do it when its hot, right? TIA!
Also: Tonight I took of the plastic shield underneath so I could access the transmission drain plug, is it safe to leave this shield off for a couple of drain and fills over the course of a couple months? or should I put it back on after each drain and fill. Its just a little bit of a pain thats why I ask.
