Here is what Shell has to say on the subject
http://www.shellusserver.com/qa/answerresult.php?rowid=13
I always do engine oil (and transmission, diff) drains when the oil is hot so that the oil drains out quickly and carries with it as much of the deposits on the bottom of the oil pan as it can. I will not even use a Fumoto or a Sure Drain because I do not want it to impede the flow of the oil.
The 60 to 70% figure Shell uses applies if you start up a cold engine just before you change the oil. Of course it does not apply to a cold engine if you do not start it up before you drain. In this case there will be just a small amount of extra oil clinging to the sides of the oil pan.
