Originally Posted By: weasley
Originally Posted By: fdcg27
There is no reason to add oil as long as the oil level remains above the add line.
How about this one. If your oil level is up near the max line, you have more oil in the engine. This means there is more oil to absorb the stresses and energy the engine puts into it. If the oil level is at the 'add' or 'min' mark, you could have anything up to 20% of the oil charge missing, so the remaining oil has to work 20% harder as it circulates 20% more often through the engine, getting 20% more exposure to heat, contamination, shear etc.
There's a reason to keep your oil topped off. Plus, every time you top up you are adding a shot of fresh additives and base oil, like a shot in the arm for the oil.
I'm not saying the other arguments aren't valid, just offering a counterpoint for consideration.
Oil helps cool an engine as well as lubricate it. Run a 5 quart sump down around a quart that's about 20% less oil to help cool and lubricate. Like I said if I went through the bother to pop the hood and the engine needs 1/2 a qt of oil I'm adding it. If I have an open bottle of oil with only 8 ounces in it, I'll add 8 ounces if the engine needs it. That gets that bottle empty into the recycle bin freeing up space. Win win.
Sure a 5 quart sump can run a quart low, I see no reason in doing so. Especially when I have the hood open to check.
