Oh yeahI remember when people would use oil along their fence line to kill grass
That was the 70s
And I wonder how the down-gradient wells are looking now from that practice ahahahI remember when people would use oil along their fence line to kill grass
That was the 70s
Explain exactly how antifreeze down my toilet is, "harming your environment"? Especially when it is defined as an accepted way of disposal in many areas.toilet is not a garbage disposal or contaminant receptacle, rd side dump as well. We're supposed to care for each other'n the environment.......
I use the same one, works great and yes, I often have all fluids in this.I bring coolant in an oil jug, never had a problem.
I also have one of these, I can bring anything I want in it and dump it in the used oil. When the system doesn't want to work with you, you have to work with the system.
That's what I do with it. And I will continue to do it until someone provides at least somewhat of a convenient disposal method. The biggest danger out here in the desert, is as soon as birds and animals see anything liquid running in the gutter, they'll line up to drink it.
Dogs included. Ethylene glycol is very poisonous to animals and wildlife. You want to avoid getting it into the food chain. So down the toilet it goes.
If it was that bad, they would be scaring everyone with heavy fines for doing it. I'm sure that will be the case in another decade or so. As they find most everything to be dangerous to mankind in one way, shape, form, or another......
Much like California already has. Have they found anything that doesn't cause cancer in lab animals?
Then I'm a walking, 70 year old, cancer free miracle. As is / are the workers at Jiffy Lube, Big-O, Quick Lube, Goodyear, and just about every service station in this country........ Long before it became fashionable for people to wear those little blue rubber gloves to take out the trash and pick up dog poop.Used oil is a carcinogen, and hazmat. I want anyone handling it to know.
That's a nice drain pan. Do you ever have any issues with it splashing over the short sides? Also, what's the total capacity? I would need one that would hold at least 20 quarts. (That's right around what I end up with when I change the oil in all 3 cars). Otherwise I would have to make multiple trips.I bring coolant in an oil jug, never had a problem.
I've got the same one stored at my in-laws' for when I work on their cars. Love it. I think the label says 16 quarts.That's a nice drain pan. Do you ever have any issues with it splashing over the short sides? Also, what's the total capacity? I would need one that would hold at least 20 quarts. (That's right around what I end up with when I change the oil in all 3 cars). Otherwise I would have to make multiple trips.
I don't have splash issues with mine. Believe it's 16qt so I can do several changes with it before needing to dump it.That's a nice drain pan. Do you ever have any issues with it splashing over the short sides? Also, what's the total capacity? I would need one that would hold at least 20 quarts. (That's right around what I end up with when I change the oil in all 3 cars). Otherwise I would have to make multiple trips.
Caution! I use that same drain pan and you can't safely carry a lot of used oil in it without spillage. None of the orifices close tightly and seal, so you have to somehow keep it upright on end or flat to avoid spillage. If it is too full I can just about guarantee some oil will come out of the big plug where the oil drains in or the spout. I personally would never use the thing to transport used oil to the store. I want containers that seal when closed and can tip over in the car without spilling, and are easy to pour into the used oil tank.That's a nice drain pan. Do you ever have any issues with it splashing over the short sides?
Mine has been fine w/r to this issue. I lay it flat on a towel. Never had it spill with 10+ qts in it.Caution! I use that same drain pan and you can't safely carry a lot of used oil in it without spillage. None of the orifices close tightly and seal, so you have to somehow keep it upright on end or flat to avoid spillage. If it is too full I can just about guarantee some oil will come out of the big plug where the oil drains in or the spout. I personally would never use the thing to transport used oil to the store. I want containers that seal when closed and can tip over in the car without spilling, and are easy to pour into the used oil tank.
Exactly why I've paid both dealers and indie garages to do coolant drain and fills, and exchanges. The one time I replaced my Nissan's radiator, I had the best intentions, but the radiator slipped I spilled a ton of coolant on the driveway. Then, what I was able to collect, nobody would accept it.If you're on a municipal sewer system, somehow the chemicals are good for the system. I'm not sure how it works for septic. I was on municipal sewer at the old house, so I'd just pop the vent line and dump it down. But I can't do that at the new house.
Disposing of coolant is near impossible. No one takes it. My county has ONE facility that takes it 3rd tuesday every other summer month or something stupid. I can understand while people just dump it in the ground.
Oil is easy to get rid of. I have more than a few friends who burn waste oil in burners to heat a shop.
Never heard of putting it in a gas tank. That seems like a bad idea for an engine that isn't made for burning oil. Filtered, and in the tank of an old diesel ... absolutely!
I don't have much coolant history on any of my cars....dealer/shop always did it but the county recycling facility here actually has a barrel for it.Exactly why I've paid both dealers and indie garages to do coolant drain and fills, and exchanges. The one time I replaced my Nissan's radiator, I had the best intentions, but the radiator slipped I spilled a ton of coolant on the driveway. Then, what I was able to collect, nobody would accept it.
