Lots of ATF too as I overdo that as well.
ATF, power steering fluid, and gear oil are all recycled the same as motor oil and go in the same tank.
I used MOBIL one mixed with chain saw chips and paper for years as fire starter. Even the PAO days, it lights and burns well. One match is all I needed. Same for the short amsoil experiment. It all burns well.I once was asked if my used oil was synthetic because apparently, it doesn't burn right in a waste oil heater.
Just ask any Subaru owner!I used MOBIL one mixed with chain saw chips and paper for years as fire starter. Even the PAO days, it lights and burns well. One match is all I needed. Same for the short amsoil experiment. It all burns well.
O'Reillys (just like every place that accepts this stuff) contracts with a waste disposal / recycler company like SafetyKleen so the stores have to follow that other company's rules. Maybe it varies by area and that other party accepts waste fluids with coolant. Around here, they do not. Some employees will smell the container and if there's a hint of coolant, they told me they won't take it. What happens is the company like SafetyKleen backcharges them if they detect coolant. Whether they can't sell it or recycle it or have to use special processes to remove it, I don't know. The folks at the store aren't making the rules though..... And just because "they used to" doesn't mean anything. Rules can change, maybe some workers ignored the rules, and so on.Yes it was a O'Reilly's
You don't put crude oil into anything though. Just like there's extensive "refining" processes on that end, there's refining processes required on the recycling end too.Good thing that crude comes out of the ground pure and uncontaminated!
That's what AutoZone did with me after I recycled the Redline Oil. I brought up this conversation prior and it perplexed users on here. Finally someone else having the same issue.I once was asked if my used oil was synthetic because apparently, it doesn't burn right in a waste oil heater.
Maybe depends on the burner? The 2 garages that i bring my waste oil to have no problem with syn.I once was asked if my used oil was synthetic because apparently, it doesn't burn right in a waste oil heater.
