On some new Porsches you only change half the oil.Not sure how a quart or more of oil could remain. A quart is a lot of oil Could you explain further?
That is crazyOn some new Porsches you only change half the oil.
How do you know which half? Do you change the other have the next time?On some new Porsches you only change half the oil.
YesHow do you know which half? Do you change the other have the next time?![]()
Is it? I never change the oil in my helicopter engines...That is crazy
Same with the Mazda RX-8On some new Porsches you only change half the oil.
I am not sure what you mean by that. Our Cessna gets fresh oil 5 times a yearIs it? I never change the oil in my helicopter engines...
I mean there are no oil change for the P&WC 206 and 207 engines. You add oil and change the filter every 1000 hours.I am not sure what you mean by that. Our Cessna gets fresh oil 5 times a year
We must be brothers from other mothers! Definitely an OilChangeDelutional + boutique oil fan user here. I too am blessed with an understanding... very tolerant wife of 48 years. That part I can not explain.my ocd kicks in when i see 3,000 miles, running HPL or Amsoil, and thinking about dumping the oil... i thank God i have an understanding wife
That is interesting.I mean there are no oil change for the P&WC 206 and 207 engines. You add oil and change the filter every 1000 hours.
Only for a chip light. Our company's engine contract does not require oil analysis. Previous company has 200FH sampling requirements.That is interesting.
Do you then do an oil analysis frequently to see the contamination levels?
If it bothers you, just consider that the oil remaining in the engine galleries is like the fluid priming a pump. If you got it all out, you'd have the mother of all dry starts.
What are the different vials of oilDid this on my L84 once - mainly out of curiosity when folks drip forever (comes out instantly) and building confidence in my new extraction pump …
Have you heard of the @Patman flush?Some people do some pretty stupid things IMO to try and get every last drop of oil out. I heard of people running the engine with the drain plug out trying to get those last couple of ounces out. IMO you can kill an engine with kindness or overthinking things too.
OMG so much good oil just wasted!I've only done this when changing from oil brand/product line to another to (in my mind) help keep the mixing of the old to new as minimal as possible. When I switched from Amsoil Signature Series to HPL Premium Plus PCMO, I even shot this short video to see what I could see (slightly more exciting than watching paint dry). Basically, I saw a quart of HPL being wasted. You can hear, and see the effects, as the wind picks up as the quart flows straight through from the fill to drain holes. Warning: do not watch with sound on and a full bladder!
I no longer worry about the last drop when not switching brand/product line, as my worry has shifted in my old age as to whether I'll be able to get up off the ground after changing the oil and filter.
Darkest is end of OCIWhat are the different vials of oil
