A higher quality, say synthetic or syn blend ATF will not shear or wear out nearly as fast as a lower quality regular ATF. Equally important is keeping the fluid at a reasonable operating temp to protect the fluid from chemically degrading (oxidizing and overheating). This can be accomplished by making sure your cooling system is operating properly, or better by adding an additional cooler in warm climates or other hot operating conditions. Cooler fluid means a cooler trans, with seals and other soft parts that will hold up muchlonger. Lastly, to make ATF last longer in service, you will need to add additional filtration to the cooler line circuit. This is one thing Honda did with their somewhat unreliable FWD transaxles, to help remove some of the wear particles that were causing reliability problems in these units. The normal ATF filter found in the sump/pan of most trannys is on the suction side of the pump and cannot filter well enough to keep the fluid truly clean. A filter somewhere on the pressure side of the pump, such as in the cooler line exiting the trans, is a much better way to keep the fluid useable and from being "worn out" so quickly.
