Originally Posted By: labman
I doubt the ADBV is much of an issue on how fast the oil heats up. Even if it fails completely, oil is up to pressure in seconds.
Who said the ADBV has anything to do with the rate at which an oil heats up? I said with all this worry about how many miliseconds it takes to get flow and pressure, maybe we should worry about the best ADBV. Now keep in mind you said "oil is up to pressure in seconds". When it suits you, I'm sure I'll hear that it takes minutes for a thick oil to build pressure.
Now, consider laminar flow. I have no clue where to find the data to calculate a Reynold's number on oil flowing in a gallery. I say it is laminar,and will let somebody else prove it is turbulent.
And??
You have a layer of non flowing oil right at the wall and faster flow towards the center. The more viscous the oil, the slower the flow next to the wall where it adsorbs heat. A lower viscosity oil should pick up more heat from th ewall of the gallery.
What is this wall you speak of? The galleys aren't where the oil picks up any major heat. It picks up heat from the underside of the pistons, to some degree the cylinders during the warmup cycle, and flowing over the heads. Again, it seems that someone has not been inside an engine before.
Suppose you're right about the slower stuff being near the sides of a galley heating up more lol. Why wouldn't it pick up heat just as fast as a fast moving oil? Why would a thick oil be the only one that behaves like this. Thin oil doesn't follow this principal?
As for heavier oils running hotter, that may be true, but how hot an oil runs is different from how fast it gets up to temperature.
I see. So we can just pick and choose which theory we want to go with based on the argument at the time.
You're really grasping at straws with that one.
