Originally Posted By: Gary Allan
Quote:
But if they stop the backflow completely, it seems this would be more important than fighting over a very small difference in viscosity.
Apparently it's hard to achieve and not considered that important. Due to orientation, most GM's didn't have ADBV's at all. Once the center tube was breached, it stopps any back siphon. I have to assume that there was no substantial oil column above the filter.
But as far as a "very small" difference in viscosity ..that tends to broaden as one moves colder. Again, in your case, I wouldn't do anything other than what you're doing. Nor do I where the OEM spec'd 15w-40 for all climates. We don't have the ability yet to make an oil for all conditions. When electric oil pump systems become widely adopted (as Doug has told us are in use in some high end alloy) then many of these issues will evaporate.
Some will look at a pre-oiler as a waste of money, but I'll venture that when electric "volume/pressure on demand" systems trickle down to the commercial or mundane, you'll see them used to an advantage at the initial starting of the engine.
That is, until we have oils with a VI of 600+
That would be very neat, have the pump kick on a second before the engine fires. I do run a preluber on the GN. Originally for shutdown, not to prelube the engine but I'm sure it helps.
I'm not trying to argue, just to understand. You mention the column of oil. In my TL, there's a nearly foot column of oil above the filter and although the filter is oriented upright, the ADBV does make a difference on this car. It's maybe half a second difference in the amount of time it takes for the oil pressure light to go out if it sits overnight.
The GN is the same, but the filter is oriented nearly parallel with the ground. Of course, my results (pre-preluber) went against everything that is taught here and even my own common sense. It got pressure faster with a thicker oil. As it became worn, you could hear the rods rattle for the first second and literally as the guage moved it would disappear. I'm not sure if the thicker oil produced a better seal in the ADBV or if it helped the primative pump seal up and not bypass as much between the gears and end plate.
