It would prove if one oil brand vs another disperses heat better.
The main issue was "Does synth's base oil make engines run cooler than a dino's base oil in the same engine under normal conditions?"
The problem is that we would not test base oils but, motor oils. I guess if we had access to nothing but base oils it would work but The point I was going for is that people are stating that synths cool better. Is it the base oil or maybe the additive package, Like the statement of certain oils "condition" seals because of the esters again, I have seen no evidence of that as well.
The fact that I have seen how if you swap different schaeffers oils in one engine, blend to mineral, mineral to blend, and not really seen much difference in extended drains, wear #'s and temp differences, but all of which are using the same basic additive package,(there is a slight difference between the mineral and blend's additives) but overall, generally the same, leads me to believe that when so many stress the base oil as the determining factor of how good an oil is, we should be examining the additives and the blending of such. Of course the base oil does provide a good base to start with(thats a given)
Example, Having looked at the maxlife additive levels on paper, told a good story, very low detergents, IMO, would not allow for longer drains as it would tend to oxidize faster due to acids not being cleaned up. Patmans test seems to support that in 2300 miles.
Redline,even though it's a full synth, tends to oxidize faster than it should, not allowing it to extend drains as much as some other full synths. why? over load of zinc/mo maybe, causing a fight between the two? Bror's analysis as well as a few others I've seen seems to support that.
Amsoil, has high levels of detergents, given a 12tbn, will allow it to fight acids longer thus a better and longer extended life and with higher levels of zddp, more antiwear protection.. but, now after running analysis on many, you find it in comparision that the tbn seems to drop faster than some others in same conditions, why, maybe lower antioxidants? still a good oil. Some other tests I've seen doing comparisions awhile back seems to support that.
Not to mention you need to justify costs just for these higher priced full synths. So what is it that does that? Extended drains, but base oil alone doesn't set the extended drain interval capablility of an oil but additives will give you a better picture to some degree.
The point is, with a virgin sample of the oil, it really can tell you how it would tend to hold up in an engine more so than just looking at flash points and such. Also, I believe that when looking at the FM/EP additives, it too will tell you how it will provide better temp control as this is what will prevent friction which is one of two things that actually causes heat. The other one a constant developed from the combustion area.
