If you get caught by a train, you just hope you survive. Everything else is secondary.When I get caught by a train I put it in P but that's so I don't have to keep my foot on the brake plus this puts less wear on my brake lights
How about just not stopping on railroad tracks?So what you're saying is best to leave it in drive so you can move out of the way quicker?
It was sierra college actually, his name was Dan or something if I remember correctly. We are in rocklin north of sac. I know that he worked with pro dragster teams and helped them shave 0.50 sec by changing their tranny fluid from gear oil (transmission builder recommended) to what he put was atf, and it zoomed after that.Interesting, that would not happen to be around Sacramento area would it? And that shop class would happen to have a rare Transmission Dyno as well?
Also Charles I would definitely put it in park/neutral if you end up having long idling time if it's over 5 minutes. Less stress worrying about hitting the person in front.
I'm lazy, so I put the F150's into park when sitting for long lights. I don't like pressing the brake that long.
Squad cars typically idle a few hours every shift.
I don't think this completely accurate. Injector output will never be zero for any length of time. If is the engine is running, the ECU MUST inject enough fuel to maintain close a stoichiometric fuel air mixture, otherwise the NOx levels go sky high and Mr EPA gets mad. Also, the cats require continual hot exhaust or they will cool down pretty quickly, which is another reason why injector output can't be at zero under prolonged deceleration.So you save fuel by idling to a stop than letting the ECU shut off the injectors and run the engine on a vacuum, which uses no fuel and also saves brakes due to engine braking.
Pretty smart.
I don't know if they have upgraded transmissions.But they've usually got upgraded components?
And yet there are automatics that are designed to be shifted. Toyota has for many years offered an auto trans with what they call "sequential shift" which not only allows up and downshifting, but encourages it. Porsche has used something similar called, I believe, Tiptronic. If you've never had the experience of being able to better control your auto trans, you might want to give such a system a try.Driving an auto like a manual makes no sense.
For those who have used such a system, it makes perfect sense.
An automatic cannot anticipate, for example, an upcoming curve. Using a convenient paddle shifter or the manual override on the stick to down-shift before a curve makes sense, depending on your driving style.I think almost every automatic has this now but I've never seen nor heard these systems be liked nor appreciated very much. It's usually been my experience that it's mainly a gimmick and you get better results with putting the tranny in the appropriate mode (sport, tow/haul, etc).
Personally speaking, I've never found using them a pleasurable experience. What's worse, most transmissions won't hold the gear, and also have a reduced range in comparison to just letting the computer do it.
I guess it might work well on some DCTs with paddle shifters, but I'll still stick with my original thought that it makes no sense. It ones thing to shift a manual tranny better than an auto shifts itself, but it's even harder to shift an auto tranny than it shifts itself.
The computer knows which gear will give you the best result for the conditions, better than you can know yourself. Therefore, why bother is my point.
