Does gasoline's octane have ANY bearing on CBU?
Mississippi
We have access to 93 octane? I realize the bigger deal is detergent/additive pkg, but does octane and by extension 100% gasoline (no eth gas) have any bearing on Carbon buildup
To answer your question on carbon buildup with 100% gas as compared to 10% ethanol gas regardless of octane...not that I am aware of!
However, there is a fuel economy benefit for 100% gasoline but, what is the delta on the paying higher prices for 100% gas as compared to just regular 87-93 octane. To me, it's all bottom line.
I have or had vehicles for 16, 18 & over 30 years and the same with lawnmower/snowblower, weedwacker/leafblower all without any fuel issues using just regular 87 octane fuel and over the past 25-30 years(that I am aware of), using 10% ethanol.
In most areas that I am aware of, 100% gas is only the highest octane gas at a filling station. All other lower octane gasoline is 10% ethanol gas. IDK where in the U.S. that there is more 100% gas compared to other regions of the U.S. I only know my area in which I live & buy fuel.
Also, some gasoline brands tout that they use the same detergent amount in all octanes of gas and others do not(the higher the octane, the more detergent).
I personally have not had any engine or fuel system failures by using just regular 87 octane w/ 10% ethanol. NOT in my vehicles, in which I have driven for decades & many 100K, 200K & 300K miles. NOR have I had any issues with my Outdoor Power Equipment(OPE).
Maybe my vehicles &/or OPE would/might run noticeably better with 100% gasoline but, I've never felt that they run poorly. Infact, everything that I own runs quite well, even perfect. They all start quickly, idle smoothly and rev freely on 10% ethanol 87 octane gas. And for the most part, meet the expected MPG!
I'm not aware that premium octane fuel is inherently E-free. I live near a large lake that sees a lot of boating traffic and several stations in town sell ethanol free 89. I've also seen E-free 90 and 91. In my case, my 1961 Briggs-powered garden tractor gives me fits with ethanol fuel - even if I'm using it on a daily basis - but if it has E0 in it I can leave it sit for 6 months with no problems.
All the premium around here is ethanol blended unless otherwise noted. CountryMark however does offer an ethanol-free premium 91 octane.
Yes, I too know folks(although it's rare these days) that still have 1960s-70s OPE and outboard boat motors/power watercraft(PWC) that don't like the E-10 fuel. However, I believe that everything you can buy today is designed for E-10 gas. These OPE/PWC may in fact run better on non E fuel but, I don't know that without trying the difference for myself.
Yes, a lot of OPE I remember seeing of recent (2010>) manufacture has labels stating "E15 max" or similar. Strangely enough, my '67 Suburban is the only one of my vehicles that runs noticeably different on the E-free 89 than E10 of the same octane. And it's not the original engine - a stock '78 350 with its original smog heads (aka, designed after the change to unleaded fuel) but with all the 67's emission-free manifolds, carburetor, and ignition.
Only one place in Waco sells E-0 unleaded gas (Murphy's on Franklin Ave) and it's 87 octane. I have been buying it for all my OPE since Texas heat + E10 = major rubber eating problems.
It smells like avgas/race gas
E10 bleep gummed up my weed whacker and my Briggs powered genset, even though I am very careful about draining and adding Stabil. It caused a minor problem with my Honda mower, but Berrymans fixed that.
No.
Yes, I too know folks(although it's rare these days) that still have 1960s-70s OPE and outboard boat motors/power watercraft (PWC) that don't like the E-10 fuel. However, I believe that everything you can buy today is designed for E-10 gas. These OPE/PWC may in fact run better on non E fuel but, I don't know that without trying the difference for myself.
I'm one of those folks who has a slew of chain saws from the 1960's forward, older yard equipment, 1970's vehicles and outboard motors. They are not supposed to like E-10... But, guess what, I'm also cheap, so they get run on regular pump gas - always. And they all still run
The fuel lines in the small 2-strokes go away, but they are easy enough to change. Otherwise, they run fine.
Carbon build-up is all about mixture control. A well tuned engine hitting the right air/fuel ratios for the conditions will not build up much carbon. 2-stroke or 4-stroke. Get any of them slightly rich and you will build carbon ...
Using the correct octane rating will minimize any build up; but--
From experience, it can.
I once bought a vehicle in which the owner had used 93 octane instead of 87 - he said it was better since the number was higher. It pinged at idle and would knock under load with any octane lower than 93. Took a look in the spark plug hole and there was a noticeable amount of grayish buildup. I finally got it back to not pinging with 87 after a few months of blending gasoline grades to gradually reduce octane. This was an 80s vehicle so YMMV.
My eB engine adjusts to octane but a number of owners suggest higher octane so we select the middle grade. It runs a bit stronger with that but never checked mileage since that was not an objective ...
The '80 Firebird FORMULA in my sig(all original) loves the E-10.
The long banned MMT which was used more in higher octane gas could cause deposits.
