- Joined
- Jul 15, 2023
- Messages
- 1,696
I’m not holding the engine variable constant...No, if the timing of an engine is fixed, it makes the same power (cylinder pressure) independent of the octane you put in.
The only variance would be how the fuel was blended, since you have have higher or lower BTU at different octane ratings. It isn't because of octane, it is because of the chemicals that aren't gasoline.
Again, you are trying to make octane into something it isn't.
