dodge ram rear window leak?
Anyone else have this problem? Basically what happens is I have the power sliding rear window and the track has drain holes. Well they get clogged up over time and then the water runs down and fills up the rear buck seat on the passenger side. I had 2" of water in the that little storage bin. I don't ever sit back their, so it's hardly noticeable, but I do believe I fixed it for about a year. Basically I took the cable off the track and blew out the holes on each side with compressed air. Some genius put the drain holes under the part when the cable snaps in. I'm thinking about drilling the drain holes out a bit larger. The water drains out the bottom corner of the window.
When the 08-up Caravan/T&C minivans went to roll down sliding door windows,they had a habit of rusting out the door bottoms due to water intrusion.Sometimes its best to keep it simple and have a fixed window instead.
