My work van is a 2005 Dodge Sprinter 2500 with 186k miles, and about once a day it will go into derate. The first time I was on flat land and couldnt pinpoint when that happened. I just slowly came to realize I had the pedal on the floor to barely hold 60mph.
The last two times, it was while climbing a hill, and I could tell when it happened. First the trans would upshift, then the turbo whistle would go away, causing my speed to rapidly drop.
I have noticed that it gets quite hot going up those hills, and goes above the notch on the gauge for 215F. Running about 230-240F sometimes. I shut off the AC now when I start up a hill to give it a little more cooling capacity.
My suspicion is that is what is triggering the derate, but I cant tell. I dont have the secret Mercedes technology to read it out, I can only get code numbers, and it just says "No Boost" which is one of those no duh things. I can tell it has no boost quite easily.
I was playing with the fan and I think its a bit on the loose side, so I might try to talk them into letting me put a fan clutch on it. Has anyone run one of these vans before? Im thinking I should hear the fan locking in on hills when it gets real hot like that.
