First of all
I too have just leased a new 04 Dodge Ram Quadcab with the Hemi, with the intention of purchasing it at lease end (assuming it's a good truck). I took delivery on Feb 28/04 and only have about 1300 Kms on it to date. My intentions are as follows:
Factory fill and filter: change at 750 kms (Pennzoil Conventional 5w30 and Napa Silver Filter)
At 2000 kms: repeat the above
At 5000 kms: repeat the above
At 10000 kms: repeat the above
At 15000 kms: repeat the above only switching to Amsoil 5w30 (ASL) and SDF42 filter
At 25000 kms: repeat the above
At 35000 kms: repeat the above and using 1 year or ~30000 kms for the oil change interval with a filter change and top off at 6 months into the oci.
Please feel free to comment and let me know if you think I'm crazy. If I decide to do UOA on all the above I will gladly post the results.
Bron, you sound like a do-it-yourselfer, I would recommend at least breaking in your new truck (15000 Kms min.) prior to installing the by-pass filter. Just a word of caution, and maybe something to look for, when I did my first oil change at 750 Kms, I noticed quite a bit of condensation on the inside of the oil fill cap and in that large plastic fill area under it. Enough that I had to wipe it down with a rag. I am not sure at this point where it came from as this truck doesn't do any short trips. Maybe the cover was not on properly from the factory or something. I am definately keeping an eye out for this at my next oil change. I doubt it would be, but if this is common for this engine, I would not put the by-pass return line in this area as this would only add/introduce moisture in your oil supply.
Enjoy the new truck.
