My 2016 Dodge Grand Caravan 3.6 is starting to get engine tick from the rocker arms, presumably. Is there a particular brand of rocker arms that would be more durable than the others?
We buy their products any way.These manufacturers should be ashamed of them selves. Been building engines for over 100 years and now we can't keep cams and rocker arms together.
....could switch to Teslas?We buy their products any way.
Melling may actually be the OE supplier.
I have a pentastar in my promaster 2500. Some go 500k and some don't make it to 100k.
It really is poor quality. Other manufacturers have been using roller rockers for 30 years and have little to no failures. It seems the needle bearings are inferior. Once the bearing comes apart there isn't much time before the cam(s) are trash.
Good news is that FCA had made well over 10,000,000 of these engines, so used parts are plentiful.
Since the rollers don't get oil directly, it's a hard statement to blame engine oil for the failures.
Exact same as the HEMI lifter failures (the pin has improper heat treating, the needles groove the pin, then the needles pile up and the roller stops rolling), that folks blame on oil, poor engine design, and all sorts of other nonsense. Clearly, FCA and GM both have an issue with their valvetrain component supplier.It's not the bearings that fail, it is the center pin they ride on that wears down.
*from my Jeep*
Additives aren't going to prevent failure as the result of a mechanical/manufacturing defect. These are hardened surfaces, like the pin in the rollers on the lifters in the HEMI. If that hardening is improperly applied and there are spots that aren't as hard or aren't hardened, those areas are going to wear prematurely and create other issues.I have a 2018 Wrangler with this engine, I have been debating a additive to combat this. The zinc additive from Rislone is readily available. The engine starts dry every time it sits more than a few minutes.
Our 2016 T&C ticks on cold start for 1 second. Usually silent on restarts the rest of the day. I think the lifters are surface treated inside to reject oil?I have a 2018 Wrangler with this engine, I have been debating a additive to combat this. The zinc additive from Rislone is readily available. The engine starts dry every time it sits more than a few minutes.
