Rocker Arm Assembly installation
MN
Maybe the Critic can help me here. I have a thread at mdxer as well.
My goal was to fix the RMS then I saw this leak.
I was wish-washing to do or not to do. To do, then I messed-up putting it back. See broken shaft holder in the middle.
Searching everywhere for a rocker arm asm with no result so I bought a broken timing belt engine just to get the rocker arm asm.
Before installing this new rocker asm, does anyone has a special secrete to share on how to install it?
Looks like overhead cam engine. I'm familiar with Ford 4.6 overhead cam engines and if I'm correct the problem you have is you can't swap camshaft caps to fix the broken spot.
The camshaft caps are line bore to the specific cylinder head. The correct fix is to replace the whole cylinder head.
