Originally Posted By: KonaMustangGT
I try to check it every 1000 miles. My car tends to consume a quart every 5000 miles. I don't what percent is going through the PCV line. Not sure want to mess around with this during a long highway trip.
Back in September I took my Mustang on vacation from MO to TX and back. I was gone a week and put about 1,800 miles on the car. When I finally checked my catch can, I had about 2,400 miles on the car since I had checked the catch can the last time. I had about 2 ounces in the can and still had plenty of room before the can was full.
I assume that if you check your oil about every 1,000 miles, you would also check it if you were taking a longer than normal trip.
Obviously catch cans are not mandatory and if you don't want to run one, I'm sure your car will run fine since most people with Mustangs probably don't run one.
As much oil as mine pulls through, I'm glad I have one and I don't have a problem checking mine occasionally to see how much is in it and to drain it.
Wayne
