So, I was re-clamping my pcv/catch can hoses the other day, and wondered where the air comes FROM to feed the crankcase ventilation system. This is a 1.6 Hyundai 4-banger DOHC.
My hose for the catch can comes out of the camshaft cover into a connection point molded into the rubber boot downstream of the filterbox, upstream of the throttle body junction.
Bolted onto the aluminum throttle body downstrream of the boot-hrottle body junction is a flange, and off of that is a larger diameter hose that goes to the cam cover. I know the first hose I described is pulling into the throttlebody, because I've tested it with a vac gauge.
Is the second hose the supply for the PCV? Or is there another air supply into the crankcase also? I don't see any other hoses coming off the intake or filter box or ducts that go anywhere..
Thanks!
Thanks!
