Originally Posted By: HangFire
Originally Posted By: dnewton3
4) The media will always be protected by the bypass valve, even if you don't fill and have a "dry start". The media is no more likely to be damaged at a dry start than when you open the BP valve during a cold start event with high-vis lube. I see this as the "ying" to the "yang" of pre-filling. Either way you're going to get unfiltered oil downstream of the media for a short time. Get over it guys; it' happens either way. And because of this, I lead into my final point ....
Bypass? This is WRONG from a fluid dynamics point of view, and those trying to use pre and post pressure sensors don't "get it" how fluid flow and pressure works in the presence of an air gap, especially at cold temperatures.
If oil practically never tears media, please explain the current Purolator situation, which may have correlation with the recent harsh Winter weather.
Also any manufacturer selling new oil not suitable for immediate lubrication duties would be driven off the market very quickly, as would every filter-less motorcycle and decades of outdoor power equipment engines.
The delta-p across the media is only dependent on the oil viscosity, oil flow and the resistance of the media. The delta-p across the media will be the same regardless if the oil filter is bone dry when the oil flow hits it, or if it's totally full of oil when the flow hits it.
If starting engines with bone dry oil filters was a dangerous thing to do that tore media all the time, then filter manufacturers would tell everyone to pre-fill the oil filter.
The media tears on Purolators has more factors involved then just cold thick oil in the winter months being flowed through them. Yes, it's one factor of many ... but a factor that "push the media over the edge" which could have contributed to the media to tears.
