Nope, he said ratio, not actual length.+2 means his arm span is 2 inches longer than his height.
I'm not talking about your luxurious body fur, I'm talking about the ratio of your arm span to your height. I'm a bit of an ape with a +2 ape index.![]()
Like Quattro Pete said, the ape index can be expressed as a number that you get by subtracting your height from your arm span. Or you can calculate the exact ratio.Trying to picture this in my head. If your arm span is 6 feet, you are 3 feet tall?
Ok, you left that bit out.Like Quattro Pete said, the ape index can expressed as a number that you get by subtracting your height from your arm span. Or you can calculate the exact ratio.
https://www.99boulders.com/ape-index-calculatorOk, you left that bit out.
That TOO says it's a ratio. Not what you get by subtracting your height from your arm span.
How to calculate: Wingspan / Height
Example: Daniel Woods, arguably the greatest boulderer of all time, is 5′ 8″ (68 in) with a 72-inch wingspan. To calculate his ape index as a ratio you divide his wingspan by his height:
72 in / 68 in = 1.06
When expressed as a ratio, Woods has an ape index of 1.06.
So I repeat, if your arm span is 6 feet, you are 3 feet tall if your ape index is 2?
Not in a way I would need a tape measure lol. I measure drums and rotors with a micrometer for like runout and stuff but never have actually measured one with a tape measure. A tape measure is one thing nobody in the shop has come to think of it lol. It’s the tool I have the least of too.You've never measured a wheel base or a brake rotor or drum? You have never measured suspension components or adjusted headlights? Just to name a few applications. Ever cut a roof rack to width? Ever fabricate anything?
You need a tape measure to calculate your ape index.Not in a way I would need a tape measure lol. I measure drums and rotors with a micrometer for like runout and stuff but never have actually measured one with a tape measure. A tape measure is one thing nobody in the shop has come to think of it lol. It’s the tool I have the least of too.
I didn't suggest measuring runout with a tape measure.Not in a way I would need a tape measure lol. I measure drums and rotors with a micrometer for like runout and stuff but never have actually measured one with a tape measure. A tape measure is one thing nobody in the shop has come to think of it lol. It’s the tool I have the least of too.
Have you figured out your ape Index yet?You need a tape measure to calculate your ape index.
As best as can hold a tape measure with my arms spread eagle, it's close to 1.Have you figured your ape Index out yet?
Only one arm is needed if you have a metal tape measure with an end hook. Also good for measuring spring length, suspension sag and useful for other cabalistic rituals.So a wide wing span and a tape measure can be used to measure toe in?
