Do you drain your air compressor tank?
I think 95% of this is governed by where you live, and the relative humidity there. I live in the desert Southwest, and NEVER drain my compressor tank, EVER. But the relative humidity is well under 20% most of the time, and can be as low as single digits. So there is no need. The air going into it is bone dry.
I noticed the OP is from Houston, one of the most humid cities in the nation. I don't think you can drain it enough under those conditions. And if possible, look into some type of dryer.
I can get like 5 or 6 ounces out of mine after just a couple run cycles. I hooked an out hose to my and empty it into the sink so I don't have a rusty mess all over the floor.
There is always some moisture in the air and it is separated out when the air is compressed. If I was painting and used a water/moisture separator, why not drain the water out every day or after every big paint job. Just my thoughts. Ed
