Do these two oils differ substantially ?
on the road in NE Oklahoma
Mobil 1 5w-40 European formula FS /X2
vs
Mobil 1 5w-40 Formula M
The only labeling difference I see is the Formula M meets the 229.5 spec. and the other bottle doesn’t mention it.
How to find out the difference between the 229.3 and 229.5 specifications ??
Muncie, Indiana
They're different oils, the Formula M is closer to a mid-SAPS oil while the FSX2 should be around 1.36% if I remember right even though it's not listed on the datasheet anymore. I doubt anything would be damaged mixing them but mixing them may result in a mixture that no longer meets the stringent requirements of MB 229.5 for extended drain intervals.
