Originally Posted By: GMFan
I'd say synros will wear out if you downshift gears without rev-matching.
If I'm driving 45 mph and come to a red light, I'll brake, and then shift into neutral just before the engine would stall (~10mph). Only when I have to give it gas will I shift into the proper gear to accelerate. I only downshift to slow down in snowy or icy weather. Otherwise, I let the brakes do the slowing down.
Downshifting to slow down in everyday driving definitely puts more wear on the drive train, clutch and transmission....of course if you drive a stick shift like 95% of the population. For those that rev-match, the wear and tear won't be too much.
My friend has a 2003 Mustang Cobra SVT and he blew his syncro in 2nd gear. He has to double clutch to get into 2nd, or just go from 1st to 3rd.....he beat the [censored] out of his car and it has 29k miles on it.
So, manual transmissions will last almost forever, as long as you don't drive it like a fool or abuse it. If you grind your transmission or spin your tires a lot, be prepared to replace your transmission.
Wow, he buggered a T-56! That's an expensive problem.
