Will some ATF fluids "clean" a transmission the same way the detergents in some motor oils will clean gunk, sludge buildup, etc., from motors? Specifically, I'm referring to Valvoline MaxLife DEX/MERC ATF - http://www.valvoline.com/our-products/automatic-transmission-products/maxlife-dex-merc-atf .
I have a 2004 Toyota Tacoma 2WD truck with appx. 160K miles on and the truck runs perfectly.
I'm planning on changing the automatic transmission fluid since I don't know when it was last done, even though my local Toyota dealer has maintained the truck "by the book".
I was planning on dropping the pan and cleaning it as well as the filter, but my local Toyota dealer (where the truck was purchased) parts department salesman said, "If it was my truck, I'd just drain the fluid and refill with clean fluid". He said my AT doesn't have a filter that you change - it's just a metal screen filter that you clean and re-install. He said if the transmission doesn't leak - why bother changing the gasket, which I kind of agree with. He was also nice enough to mention that he doesn't think I need to buy specific Toyota ATF fluid - he said the Valvoline was fine as long as it meets the Dex III spec (which it does).
I've heard good things about the Valvoline MaxLife DEX/MERC ATF, but I'm just concerned that if my transmission does have any gunk buildup, that the new fluid might cause problems?...or do you think I'm O.K. just to change it and not worry about the potential "cleaning" effect.
Thank you,
Ed
Thank you,
Ed
