Do LED lightbulbs eliminate the need for rough duty light bulbs?
GON
$175 Site Donor 2026
White Sands, NM
Earlier today I replaced four failed incandescent garage door opener light bulbs.
In the past install rough duty light bulbs on garage door openers to increase the life of the light bulb. Today I installed LED bulbs, with the hope the LED bulbs will last as long if not longer than rough duty incandescent light bulbs.
Wishful but flawed thinking- or a smart move?
Well all of our new openers came with LED's (and list of suitable replacements), so I would say yes. I have also gone to led's on the others and no faults yet. I'd say that between a heavy duty, but still fragile hot filament and a solid state led, that the led should be inherently more durable. Maybe not a problem any more, but some older led's would jam garage door opener signals....ask me how I know.
No because I have a rough duty bulb I installed in 2013 I think and I've never had an LED last anywhere near that long.
My experience was the door opener was tough on LED bulbs that tended to have short lives anyway, like some filament type LEDs I bought, and some off brand freebies the electric distributor was giving away. The Feit half dome type bulbs I replaced those with have lasted just fine.
IMO, bulb life is a marketing gimmick. If you use a bulb like normal, i.e. turning the light on and off, it's life is reduced by 50% if not more.
I haven't seen rough-duty bulbs in ages. I recall that they are exempt from the gov't mandate requiring incandescent bulbs go away due to energy usage but I don't see them in stores (not that I look either). We used to get dozens of them every year when my Dad was an electrician for the city I grew up in. They used them in traffic lights and bought cases of them every year. Someone decided they can't have any leftover at the end of the year so workers got to take them home. They gave off the worst light too.
Quality counts.
Worst are CFL. Forget about it. Environmental failure. I have buckets of failed CFLs.
Regular duty, cheapo incandescent bulbs. NG. HD ones I got some slightly better life back in the day.
LED. So far GOOD QUALITY outdoor use LEDs are lasting and lasting for us. So yes.
Worst are CFL.
I worked at an electrical supply house when I was younger and CFLs were being introduced/marketed at that time. The Sylvania rep gave everyone a bunch of CFLs and my wife and I had some that lasted at least 10 years. Problem was they cost $12-15 each and incandescents were $1/each or something. Doesn't matter if they last 10-15x longer, no normal person cares or will "do the math" to show they're worth it.
LEDs can be very reliable but quality varies. I have a bunch of LES bulbs, some smart WiFi ones, some regular ones. Over the years I’ve had maybe one or two per year fail. Some quite spectacularly with a bang or smoke.
PIAA, Hella, KC Highlights etc have gone to LEDs as the longer life over halogen. LEDs don't have any filaments that get brittle with heat cycling.
Be aware that many standard LED bulbs will cause RF interference with certain garage door openers. It has been a problem with a couple of different Chamberlain made units (e.g., LiftMaster, Craftsman, Raynor) where the RFI will diminish the remote transmitter's range by up to 90%! To get around this issue, you can install special LED bulbs with a RF suppression circuit designed for GDOs. I have had excellent results with using these TORCHSTAR LED bulbs purchased from Amazon.
Yes imo they do replace rough duty.. but they cant be 100% enclosed if you are going to have them on for longer amounts of time.
and wrong ones can interfere with door opener signal.
I had one that totally blocked the signal.. wouldnt work right outside the door.
Swapped it for a different brand and now it works 200ft away again.
My only complaint is that with GE CFL Bulbs they had 2700k (Dingy yellow) 3200k, 3700k (the bulbs with the blue base and a little reddish) 4100k, 5000k, 5200 full-spectrum and 6500 with an ever so blueish tone that mimicked daylight. In automotive applications HID is still the way to go.
Somewhat related but I'm at a 75% failure rate with Philips Ultra Definition LEDs. Purchased them because of their high 95CRI spec but 9 out of 12 bulbs have failed within a year. Wanted to love them but this is ridiculous. Philips has been good about honouring the warranty with minimal hassle, but even one of the revised bulbs has already failed.
https://ledflicker.wordpress.com/2023/08/19/philips-ultra-definition-95-cri-a19-led/
Strangely enough I've had good success with IKEA >90CRI bulbs. I may switch to those altogether.
I put Great Value LED bulbs in my garage door opener around 2016-2018-ish and haven't had any issues. I would have to replace rough duty bulbs yearly.
  • Helpful
Reactions: GON
i learned something to day. I try to learn daily even if I don't want to.
I've read this but haven't encountered it. I usually just buy LED bulbs from Walmart (most often, their Great Value bulbs) and have no issues with our opener.
