Do I have a bad PCV valve?
Phoenix, Az
I bought a new PCV valve from Napa that I'm getting ready to install in my 2011 Kia Soul. I know it's supposed to let air through in one direction only but I couldn't help but test it by blowing through it. Air passed freely in one direction as it should but I was surprised that in the opposite "closed" direction it wasn't 100% sealed, I could hear a small amount of air passing through. It was a very small amount but it was there, and it stopped when I put my finger over the end. Is this normal/acceptable and close is good enough, or is this just a poor PCV that I should just return? I wouldn't think these things would be that tough to get right for aftermarket mfrs.
Sounds normal. The mechanism inside controls it..typically if when you shake it you hear the spring its fine. If not ok you may see some consumption..
