I have replaced the LIM gaskets on my 1999 Olds GLS. I used Dorman because it came with the bolts and it was in stock at the local NAPA store.
Let me make some general points:
1. Everything about the original gasket was wrong, not just the plastic base. The gasket also failed because the area that actually formed the seal was too small and crushed when the manifold was tightened.
The manifold can also leak because there is an area about 3" below the intake that is only sealed with RTV silicone.
This picture
http://info.rockauto.com/ROL/DetailRemote.html?MS4504.jpg shows the revised design. The black area was changed to rubber coated soft metal, the red area forms the seal and was made larger, and metal tabs were added at the bolt holes.
2. Why are bad engineers' choices made ?
"Golden-boy" syndrome. Watch a documentary about why building collapse or why airplanes fall apart in the sky.
Lots of bad engineering choices are made because the higher manager will follow whatever the "golden boy" says. An experienced engineer will then say "that ain't gonna work".
The experienced engineer will be chastised for not being a "team player", and then everyone else will just go along with the "golden boy" .
After knowing that they made the wrong choice, the manager will defend his choice to protect himself. The company then does a cost analysis, and determines that it is cheaper to fix 1000x failures then to use 10000x corrected parts.
