Originally Posted by hatt
Neat. You have a pic of the cover?
The only factory aluminum covers I've noticed were on Nissans. I just figured they were swag like a chrome exhaust tip. They certainly aren't heavy haulers like a ton dually diesel.
Edit. I found a pic. Looks like the exact shape of steel covers. Aluminum with a lot of fins. I'm sure that does cool better than a stamped steel cover.
The problem with the Titan is that when it came out, it had a Dana 44 with a stamped steel cover. The Dana 44 was arguably undersized for the application, and when people towed, the diffs would occasionally overheat and self-destruct. So Nissan put an Aluminum diff cover on for better heat dissipation.
Weird. GM has used the 10 bolt rear for decades without major issues.
The GM 8.5" holds more gear oil than a Dana 44 8.5". Dana's in general call for quite a bit more bearing preload as well.....Especially the carrier side bearings!
