I ask because I just had my CA emissions test and to my surprise, my NO measurement went down as well as my HC count. At the time of my last test, I had just replaced the cat converter and had put maybe a couple hundred miles on it before the test and these were the results:
In those two years, I've done MAYBE 10k, one oil change with the same oil/filter combo, and a coolant flush...that's it. The results from today's testing are:
With everything just about the same (both times cars were driven on the freeway prior to the test, car didn't sit before test), the only thing I can think of is the cat needed a break-in or the coolant was bad and the cylinders weren't cooled properly?
Either way, glad I passed...opinions on the readings?
EDIT: This is on my 3800 II 1996 Camaro with 180k miles.
