Do cartridge filter setup have an ADBV?
Quote:
....However, I was (Do cartridge filter setup have an ADBV) looking for info on the cartridge filters and how a stand-pipe might stop a cartridge filter from emptying overnight and causing dry starts in the morning....
As I said, can't speak to your specific application, but 'if' a cartridge filter had a standpipe as the poster alluded to, the concept would be the same as spin on. The nylon centertube would have a solid or non porous area/potion designed to hold the oil in the housing, similar to holding oil a spin on/canister filter after shut down.
But as noted in the link, some sort of adbv or check valve would also be required to keep the oil from draining back.
As my prior quoted portion implies, trying to explain the standpipe concept, not point to a specific cartridge application.
