Originally Posted By: XS650
I do have a question.
If I plug the tire myself, will that create any problems getting a proper repair later?
I think that will depend on who does the followup repair. Some folks will be skeptical about doing a proper repair when someone else has done an earlier plug.
I have a car with run flats that I take long trips in and no spare and no room for a spare. I have also heard that most tire dealers can't dismount-remount my Goodyear run flats on a Corvette because it takes special equipment and training.
I can't say specifically about Corvettes, but I suspect the tires are just plain difficult to mount and dismount and because of the TPMS, require a bit of care in the process. This means that the tire dealer ought to have a mounting machine that will do the hard work (instead of the tire buster), and the guy has to be trained about how to do it.
This combination may exclude quite a few shops - and some shops will probably disqualify themselves because of the costs. Replacing a TPMS is not only time consuming, but it's expensive, too!
Oh and while I'm at it:
Originally Posted By: aaxb970
Just to clear up 1 thing...the tire was fine when I got home it went flat overnight....I must have picked up the offending object on my street.....so the tire was not driven on underinflated....
Well.....ah......Mmmmmmm.......
You could say the tire wasn't driven on flat, but unless you actually measured the pressure in the tire when you got home, you can't be sure if it was underinflated or not. That's one of the problems with not looking inside the tire. You just don't know for sure.
