There are specific measuring qualifications for where you want to put the cantenna holes to get proper signal.
This is true, but most of the time if you locate it between 1/3rd and 1/2 the way up from the sealed end of the can it will work very efficiently.
I have found the Large coffee can to be best for this out of the ones I have built. My first was using a foil coated Pringles Chip can. It worked, but not as good as the large coffee can.
I also found that if you cover the outside of the coffee can with brass mesh (that looks like window screening) it will block outside interference and can boost the signal up to 25%. I just wrapped 2 layers of this around the can and then duct-taped the heck out of it. The brass mesh stops any kind of RF around the can so that the signal inside the can is super concentrated and free of noise.
I won't tell you how much time I have
wasted spent on this.
What I will tell you is that my dad has a 10 foot solid Aluminum C-Band TV dish and I want to put a receiver on it and see what I can pick up then instead of using the 18" Digital Dish like shown above.
It's about 20ft away from the house so I will need to boost the power on the USB cables to get it there.
This is what the brass mesh looks like. The one shown below is Copper but it's the same only Brass. (Couldn't find a picture)
Now all the networks I pick up that are unsecured I mark down and drive around on spare time (usually weekends) with an antenna I have on the truck that sticks to the roof with a magnet. I then find the source as best as possible and try to notify the owners that their network is wide open. If I can't find the network because the houses are too close together I see if their computer is visible on the wireless network and place a file on their desktop (some hacking knowledge I have) telling them they are open for attack and how to fix it. I don't tell them who I am. Usually some months later those networks are secured. So I think I'm doing some good.
In the file it says that I was in there computer and if I was able to put a file on their desktop warning them of what I did then they should know that others with malicious intend may not be so nice... I scare the $#!@ out of them so they get the picture.
You would not believe how many networks are wide open. The antenna on the truck is the best thing I have bought. (Entertainment)
