Let's see... Tens of thousands in tools, the shop and a combined bazillion years of experience and knowledge...
I was told in the rust belt they just count on cutting drums off with a torch.And one last note since I'm on my soap-box.
A mechanic isn't going to disassemble you're entire brake system to see exactly what needs to be replaced and then give you a quote. At best they are going to take your wheels off and inspect the rotors and pads for uneven wear.
Also keep in mind tribal and regional knowledge. Lets say you are in New England and late 90's GM trucks are known for having rusty frozen brake calipers. Maybe 9 times out of 10 they aren't worth the trouble. If they spot uneven pad wear they will 100% want to replace the calipers. Just a made-up example but you get the point.
It isn't the 70's and we don't rebuild calipers and wheel cylinders anymore unless we have no other choice. If there is any sign that the caliper isn't working right...they will want to replace it.
So when the customer says...."My brakes aren't pulling to the left or right....my calipers are fine, you are trying to rip me off!!!" It probably isn't the case.
Your calipers are on their way out and the mechanic doesn't want you to come back in 500 miles once they finally freeze up and your brakes are toast again and you need ANOTHER brake job, this time with new calipers.
Good point but those tool costs are tax deductible. IMO, Snap On gets to charge outrageous prices for their stuff knowing this bc they know most if not all of their customers are pros that can do this as part of doing business. I think, on top of deductible business costs, additional savings are due to depreciation deductions.@JeffKeryk Spot on! My father, and many mechanics have take out insurance on their tools. Once for insurance he had to provide an itemized estimate of replacement cost for every single tool in his box. That estimate came out to over $150k including the tool box and that was the stuff just inside his box.
But but but.. I looked up the problem on the Youtubes and it said it should be a quick fix.Let's see... Tens of thousands in tools, the shop and a combined bazillion years of experience and knowledge...
And and and, I found a deal online for the part, it will get here next month, so I don't understand why the mechanic charges so much.But but but.. I looked up the problem on the Youtubes and it said it should be a quick fix.![]()
Until the pistons don't push back. Or you're ill-prepared and didn't know they were wind back pistons. Or a rotor retention screw rounds out. Or a caliper mounting bolt strips (actually common on 2nd Gen Rams)A new rotor and pad slap is something every home mechanic can do. Breaking the threads on the bleed screws and replacing calipers or the master cylinder is one level up in the risk category since you better be good at properly torquing the connections. Maybe have a gear head friend with you the first time you do it.![]()
You have to know your skill set and your tool collection. Balance that with time, energy and $$.Until the pistons don't push back. Or you're ill-prepared and didn't know they were wind back pistons. Or a rotor retention screw rounds out. Or a caliper mounting bolt strips (actually common on 2nd Gen Rams)
Anyway I'm in favor of DIY but in a driveway on your knees small problems quickly become big problems.
Or the latest ones that we see are not putting a vehicle in service mode and sending the pistons back in thus damaging the e-brake motors on the calipers. Then playing dumb and saying everything is defective.Until the pistons don't push back. Or you're ill-prepared and didn't know they were wind back pistons. Or a rotor retention screw rounds out. Or a caliper mounting bolt strips (actually common on 2nd Gen Rams)
The scariest is teenage drivers (almost always male) with bolt-on aftermarket everything like headlights, taillights, CHMSL, light bar etc. They buy the cheapest components that "look cool" and install with a Great Neck socket set from the dollar store.Some DIY know what they are doing however it’s a massive red flag on buying any used car . People take tons of short cut and using improper tools damaging vehicles trying to maintain them.
Agreed. Sometimes the additional cost is just because I took the time to acquire it, I fronted the $ (even if just for a day) and I know WHAT to choose.There have been several posts in the last few months where BITOGers add up the cost of parts, then get mad the shop didn’t do the work at cost, and in this case state the shop is exploiting customers. Rent/mortgage, insurance, payroll, taxes, utilities, equipment, consumables, shop needs a new boiler or roof, etc, etc, etc, etc, etc, etc, etc. All this BEFORE the owner gets paid a nickel.
As a business owner, sometimes I charge $60 for a material that cost me $5, not because I’m a shyster, but because the $55 is for my knowledge and skill (I don’t have a separate labor charge). Some procedures I make a lot of profit compared to the cost of the materials and for some procedures I make much less profit compared to the cost of materials. Some things I charge more for because I don’t like doing them and the higher price is what it’s worth to me to do it.
I have no idea what other offices in my area charge for any given procedure because it’s not relevant to me. My costs and OH are specific to my particular business and I charge what I charge to cover my OH and make the living I want to make. If someone doesn’t like it, well, they called me and made an appointment, and I didn’t beg them to pick my practice. Everyone knows what the cost will be before the cost is incurred. If they want cheaper they are free to go somewhere cheaper.
My real point is, if all you did was look at the cost of materials for what I was doing, it would give you a very skewed idea of the actual cost to me to do a particular procedure. At the end of the day, I don’t feel bad at all that I made a healthy profit and that profit is how I feed my family and send my kids to college. In the end, I think I’m worth every penny.
Often it is, before youtube and BITOG I was pretty much only taking my cars to the shop, but now, I always check out what needs to be done. If its pretty simple then I just do it myself, and I tackle some tougher stuff if I have time.But but but.. I looked up the problem on the Youtubes and it said it should be a quick fix.![]()
So I took my GMC Yukon Denali for an inspection, they shop said it had brake issues, quoted me $1300 to fix it.
Upon examination, it ended up being all brake pads, 2 calipers, 2 rotors and bleeding the brakes. Got $300 in parts and did it myself in under 2 hours. Most of the time was spent jacking the car up and looking for the right sockets. I am slow and I have zero power tools. There is no way that was $1000 in labor. I spent 30 mins per wheel (and did 3/4, the 4th one didn't need it but I think the caliper is sticking thus needs replacement). I think a well equipped shop with a rack and all the tools ready can do it spending 15 mins per wheel, someone who does it every day.
No broken/seized bolts, no rusty lines, nothing special at all. I said I am picking up the car with no repairs and they acted shocked.
I get it that 98+% of the auto drivers out there don't do their own work, thus auto repair shops can exploit them. Because brake work sounds scary and most drivers out there can't tell a caliper from a you know what. I think I would have paid them $500, probably, parts plus labor. Or more if it needed the entire brake system rebuilt, like brake lines, power brake booster, master cylinder... etc. etc. What happened to these shops which did brakes only for low prices like $200 or such? I used to see them years ago, apparently not anymore.
2011 Enclave, the rear brakes were shot at 33k. Back then (about 2014 we couldn’t get the rotors off and were in a hurry). Firestone did rear pads and rotors for $280, which imho is cheap considering rotors. The rotors were in fact cheap and began turning orange in a week, and they lost the rubber plug for the adjuster screw. Been DIY since but the $280 was reasonable. It was something like $99 per axle plus extra for rotors. That’s likely cheap nowadays…And here is why the dealer is going to cost you more. I'm using my 2021 GMC Canyon as an example since I am in the market for new front rotors and pads.
RockAuto - Good Aftermarket Parts:
RockAuto - Genuine GM Parts:
- Power Stop coated rotors. $53.79ea
- Power Stop Truck and Tow pads. $53.79
- Total shipped $180.76....and they show up in 3 business days
GM MSRP:
- GM Rotors. $102.99ea
- GM pads. $84.99
- Total shipped $290.97....and they show up in 9 business days.
At the dealer you are 100% going to pay MSRP for OEM parts. The extra cost is just their markup to keep the parts on the shelf and have them readily available and warrantied by the OEM. At 2 hours of labor at $200/hr you are already at $981.76. Add tax and your at $1,043.12. Just for front pads and rotors.
- GM Rotors. $206.58ea
- GM Pads. $168.56
- Total MSRP: $581.76
Same estimate at a local repair place. Parts are roughly $400 since they came from an auto parts distributor and the distributor and the mechanic mark up the parts. $150/hr for two hours and your at $700. Add tax and your at $743.75.
This is a loose example but you get the idea. Going to the dealer with OEM parts is going to cost you about 30-40% more than a local shop using good aftermarket parts.
