I just changed the cap and rotor on my 1992 Nissan Sentra Classic (E16i engine) and really had to haul on the old rotor to get it off the distributor shaft. This pressure revealed a large amount of rotational play in the shaft (about 2" ). This slack is so great that when I put the new cap on and started the engine it would only run on 2 or 3 cylinders! I then took the cap on and off 4 or 5 times until I had gradually rotated the rotor enough, by hand, until the timing was approximately correct.
Is the slack/play in the distributor shaft something I can tighten or does this mean I need to replace the distributor? Where would the slack be coming from? The rotor was properly screwed onto the shaft and the timing adjustment bolts are tight with no give.
